16 years agoTSE IP - Enable multicast - HashEntries
Hi Sorry if my question is silly I am new to FPGA world. Using Triple Speed Ethernet DataPath reference design as my base design. Using Stratix II GX PCI Express dev kit Question Ena...
13 years agoI'd check that IOWR_32DIRECT() doesn't multiply the offset by 4.
It is actually much safer to define C structs that map hardware registers than to use offset constants. Unfortunatly that isn't the was Altera have defined things - but it can be done quite easily. Just make sure the accesses bypass the data cache.
