10 years agoTSE doesn't have data on RGMII output, functional simulation works fine (Max 10)
Hi everyone, We are using MAX 10 FPGA development kit that supports 10/100/1000 base-T Ethernet using an external Marvell 88E1111 PHY and Altera Triple-Speed Ethernet MegaCore MAC function. ...
10 years agoHi Kkaibara,
thanks for your input, appreciate that! Yeah, I realised that SignalTap can not monitor DDIO outputs, it took a while! I added PLL output shifted 90deg to run PHY. I was actually finally able to see the packets coming to the PC and monitor them their with WireShark. However, another issue came up - the packets have screwed headers time to time. So I am sending 400 bytes of data + 16 bytes of headers. And headers have same data that Payload has. I tried to monitor mentioned GMII signals in SignalTap but they also could not be gathered - marked as blue in SignalTap and stay always at zero. Are you sure they can be monitored? Any idea about screwed header data?
