14 years agoTSE and scatter-gather dma problem
hi, everyone I am recently trying to connect nios II to computor through ethernet , I separately connected a memory to stream scatter gather DMA to TSE's transmit and a stream to memory scatter g...
13 years agoSome data was transmitted via ethernet now: as I said in previous post, sgdma was initialized incorrectly.
But while catching the packets with Wireshark, I see that packets content isn't correct. Besides that the packet was transmitted only twice (instead of infinite sending), after 2 transmissions code never comes to tx_done++, so it is looped in while(tx_done == 0); I have attached zip-code of source files. The only correct information is the source mac (00-11-22-33-44-55) All other bytes should be 0xA5 (as initialized), but in fact I see such packet: CC CC A5 A5 CC CC 00 11 22 33 44 55 CC CC A5 A5 CC CC A5 A5 CC CC A5 A5 CC CC and so on... Total length is also correct (128 bytes). I have no ideas, what happens...
