14 years agoTSE and scatter-gather dma problem
hi, everyone I am recently trying to connect nios II to computor through ethernet , I separately connected a memory to stream scatter gather DMA to TSE's transmit and a stream to memory scatter g...
13 years agoDoes the Nios CPU have a data cache? If yes, then it is possible that the values you set aren't written to the TSE, but just in the data cache instead. You can try and disable the data cache, use some IOWR/IORD macros to write the TSE registers, use uncached pointers (set bit 31 in the address) or flush the data cache once you are done configuring the TSE, and invalidating it before reading the PHY registers.
