14 years agoTSE and scatter-gather dma problem
hi, everyone I am recently trying to connect nios II to computor through ethernet , I separately connected a memory to stream scatter gather DMA to TSE's transmit and a stream to memory scatter g...
14 years agoI have got the problem ,and it works OK now. there are three problem :
1. I didn't initial the TSE properly ,command_config needed to configure and enable sending and receiving . 2. I used the asynchronous transfer of sgdma, I find the synchronized transfer works OK, but the asynchronous transfer would encounter some error after just less ten transfers. I don't know why . 3. If I checked the Align packet headers to 32-bit boundaries in sopc builder ,It did not work at all. For the problems above ,would you give me some advices, thanks sincerely hjh
