MarkA
4 years agoTrouble Erasing Micron Flash using the Generic Serial Flash Interface
I am having troubles when I try to erase a Micron Flash (MT25QL256) using the Generic Serial Flash Interface in a Cyclone 5 (5CGTFD7C5). This 256Mbit flash part has 512 segments and each segment has...
Farabi_Altera
3 years agoHello,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
- MarkA3 years ago
The above link says to look in the ......asm.rpt. It is actually the .....map.rpt that shows what IP is being used and what the license status is. Here is the License section from one of my builds where the intel_generic_serial_flash_interface doesn't work correctly. But I don't see anything that looks concerning.
+------------------------------------------------------------------------------------------------------- ; Analysis & Synthesis IP Cores Summary +--------+----------------------------------------------+---------+--------------+--------------+------- ; Vendor ; IP Core Name ; Version ; Release Date ; License Type ; Entity +--------+----------------------------------------------+---------+--------------+--------------+------- ; Altera ; altera_pll ; 20.1 ; N/A ; N/A ; |top_u ; Altera ; Triple Speed Ethernet ; 12.1 ; N/A ; N/A ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; Altera ; Triple Speed Ethernet ; N/A ; Nov 2012 ; Licensed ; |top_u ; N/A ; intel_generic_serial_flash_interface_top ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_csr ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; altera_merlin_demultiplexer ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; altera_merlin_multiplexer ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_if_ctrl ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_if_ctrl ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; altera_avalon_sc_fifo ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_if_ctrl ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; altera_merlin_multiplexer ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; altera_reset_controller ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_cmd ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_addr ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_xip ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; intel_generic_serial_flash_interface_xip ; 18.0 ; N/A ; N/A ; |top_u ; Altera ; altera_avalon_sc_fifo ; 18.0 ; N/A ; N/A ; |top_u ; N/A ; altera_remote_update ; 20.1 ; N/A ; N/A ; |top_u ; Altera ; altera_remote_update_core ; 20.1 ; N/A ; N/A ; |top_u +--------+----------------------------------------------+---------+--------------+--------------+-------
