Trouble Erasing Micron Flash using the Generic Serial Flash Interface
Flavor 1 only has
- MII signals (Ethernet Interface) to the Intel Triple Speed Ethernet MAC core.
- Some custom logic that process these ethernet packets and converts them into Avalon bus interfaces and some internal custom bus interfaces
- One Avalon interface connects to the "CSR" interface on the Intel Generic Serial Flash Interface
- One Avalon interface connects to the "MEM" interface on the Intel Generic Serial Flash Interface
- the custom bus interfaces talks to other internal command/status registers
- An Intel Generic Serial Flash Interface Core
- An Intel Remote Update Core
Here are the summary statistics for Flavor 1
Family : Cyclone V Device : 5CGTFD7C5U19I7 Timing Models : Final Logic utilization (in ALMs) : 4,667 / 56,480 ( 8 % ) Total registers : 7945 Total pins : 114 / 268 ( 43 % ) Total virtual pins : 0 Total block memory bits : 114,688 / 7,024,640 ( 2 % ) Total RAM Blocks : 20 / 686 ( 3 % ) Total DSP Blocks : 0 / 156 ( 0 % ) Total HSSI RX PCSs : 0 / 6 ( 0 % ) Total HSSI PMA RX Deserializers : 0 / 6 ( 0 % ) Total HSSI TX PCSs : 0 / 6 ( 0 % ) Total HSSI PMA TX Serializers : 0 / 6 ( 0 % ) Total PLLs : 1 / 13 ( 8 % ) Total DLLs : 0 / 4 ( 0 % )
Flavors 2,3,4,5 have
- the exact same things listed in flavor 1 plus the following
- Various processing functions
- Intel Cores (Reed Solomon Decoder, Viterbi Decoder, FFT)
- Third Party Video Encoder Core
- Custom Radio signal processing blocks (Filters, FEC Decoders, Protocol Decoders)
Here are the Statistics for flavors 2 and 3 (4 and 5 are similar)
Family : Cyclone V Device : 5CGTFD7C5U19I7 Timing Models : Final Logic utilization (in ALMs) : 38,276 / 56,480 ( 68 % ) Total registers : 60421 Total pins : 114 / 268 ( 43 % ) Total virtual pins : 0 Total block memory bits : 1,426,677 / 7,024,640 ( 20 % ) Total RAM Blocks : 262 / 686 ( 38 % ) Total DSP Blocks : 156 / 156 ( 100 % ) Total HSSI RX PCSs : 0 / 6 ( 0 % ) Total HSSI PMA RX Deserializers : 0 / 6 ( 0 % ) Total HSSI TX PCSs : 0 / 6 ( 0 % ) Total HSSI PMA TX Serializers : 0 / 6 ( 0 % ) Total PLLs : 1 / 13 ( 8 % ) Total DLLs : 0 / 4 ( 0 % )
Family : Cyclone V Device : 5CGTFD7C5U19I7 Timing Models : Final Logic utilization (in ALMs) : 39,758 / 56,480 ( 70 % ) Total registers : 73475 Total pins : 114 / 268 ( 43 % ) Total virtual pins : 0 Total block memory bits : 2,059,980 / 7,024,640 ( 29 % ) Total RAM Blocks : 327 / 686 ( 48 % ) Total DSP Blocks : 136 / 156 ( 87 % ) Total HSSI RX PCSs : 0 / 6 ( 0 % ) Total HSSI PMA RX Deserializers : 0 / 6 ( 0 % ) Total HSSI TX PCSs : 0 / 6 ( 0 % ) Total HSSI PMA TX Serializers : 0 / 6 ( 0 % ) Total PLLs : 1 / 13 ( 8 % ) Total DLLs : 0 / 4 ( 0 % )
