14 years agoTriple speed ethernet problem
Hi Guys I have problem with the triple speed ethernet:(. I can't transmit any thing and output equal zero all the time:eek:. this is a snap shot of the signal tab ;) Thanks in advance for eve...
14 years ago --- Quote Start --- I would suggest to use one of the software examples first (such as the simple sockets server). They use the Interniche TCP/IP stack and some ready made drivers. This will at least let you know if there is a problem on the hardware side and/or the interface between the TSE and the PHY. Once you got that working, you can start implementing your own solution if you want. IIRC there are a few steps necessary before you can read/write data on the TSE, such as setting up the MAC address and configuring the link speed. I also see that you are sending the preamble. You shouldn't do that, it is automatically added by the TSE. --- Quote End --- Good suggestion i will try to apply it. The weird thing is the output from TSE all the time is low and the TX led is blink when i transmit anything, so the TSE and phy are working because they know when i transmit any data.:confused::confused:
