14 years agoTriple speed ethernet problem
Hi Guys I have problem with the triple speed ethernet:(. I can't transmit any thing and output equal zero all the time:eek:. this is a snap shot of the signal tab ;) Thanks in advance for eve...
14 years ago --- Quote Start --- What software are you using to communicate with the TSE? Does it say anything? Could you check the ready signal from the TSE on the Avalon Stream input? Can you communicate with the PHY on the MDIO interface? --- Quote End --- Thanks Daixiwen for your reply. I am using NIOS II and i can write on any register i want, so i wrote on the command register to enable the TX and RX and after that the TX and RX leds are blinks and also the led in router is blink. The problem i can't capture any packet and the output from TSE always low. The ready signal always high, so that means it is fine.
