14 years agoTriple speed ethernet problem
Hi Guys I have problem with the triple speed ethernet:(. I can't transmit any thing and output equal zero all the time:eek:. this is a snap shot of the signal tab ;) Thanks in advance for eve...
14 years agoWhat software are you using to communicate with the TSE? Does it say anything?
Could you check the ready signal from the TSE on the Avalon Stream input? Can you communicate with the PHY on the MDIO interface?
