14 years agoTriple speed ethernet problem
Hi Guys I have problem with the triple speed ethernet:(. I can't transmit any thing and output equal zero all the time:eek:. this is a snap shot of the signal tab ;) Thanks in advance for eve...
14 years agoI assume that you don't have a license for the TSE-IP.
In that case the TSE only keeps on working as long as you don't close that small message box that opens after downloading the logic onto your FPGA (using the JTAG port). If you close it, the TSE will not transmit any longer, but will keep on receiving, putting you on the wrong foot ...
