12 years agoTriple speed ethernet performance
is somewhere some application note like was AN440, where they were tested some types of ethernet applications and table with benchmark test results (in attachment AN440) ? I use DP83848 with IgorMac and uClinux driver, which is 10/100Mbps PHY and i would like to use new faster PHY. But I show to the table 4 (on 24 pages), where max. speed was 108Mbps for TX and 74Mbps for RX operation, it is not big motivation to choose another PHY.... Which PHY can you advise me ? How fast can you transmit and receive data on ethernet interface ? Before 3 years I tryed DK-DSP Stratix III board, but ethernet did not work with TSE and Marvell 88E1111 (it was connect for optical medium, i think and uclinux could not able to recognize it). Thank you for your answer. Jan Naceradsky11 Replies
You can check this example to see how to generate or receive UDP packets in hardware: http://www.alterawiki.com/wiki/nios_ii_udp_offload_example
