Zarquin
2 years agoTriple Speed Ethernet MII/GMII - Timing Issue
When I send a UDP Broadcast packet from the PC to the board, the packet is visible on the GMII RX lines coming from PHY. But data do only sporadically arrive on the Avalon-ST RX bus - see post TSE ...
Nurina
2 years agoHi,
I have sent you an email. You may share your design there.
Please find the email subject "Intel Customer Support - Case #: 06005652"
Please let me know which Quartus version you are using as well.
Nurina
- Zarquin2 years ago
Found the cause:
The cause was the licence evaluation dialogue. The dialogue text was not readable on my computer (see figure below) and the window was often hidden behind other open windows.
So I sometimes closed the window and sometimes left it open because I couldn't see it.
When you close the window, the ip core no longer works. - But how can you tell if the dialogue is'nt labelled?I found the clue here:
community.intel.com/t5/FPGA-Intellectual-Property/TSE-MAC-catatonic/m-p/155152#M12528Fig. Evaluation dialogue
