Zarquin
2 years agoTriple Speed Ethernet MII/GMII - Timing Issue
When I send a UDP Broadcast packet from the PC to the board, the packet is visible on the GMII RX lines coming from PHY. But data do only sporadically arrive on the Avalon-ST RX bus - see post TSE ...
Nurina
2 years agoHi,
Thank you for using Intel Communities. Please allow some time while I investigate your problem.
In the meantime, is it possible for you to share an isolated design containing the TSE IP?
Nurina
Zarquin
2 years agoYou find the IP Core attached.
Do you have a mailbox address?
