GDagi
6 years agoTriple-Speed Ethernet IP not processing data (Instantiation Issue?)
Hello, I've begun work with the Triple-Speed Ethernet (TSE) IP in order to simulate packet receiving and sending. I have an external packet generator alongside the main and testbench verilog files. ...
SengKok_L_Intel
6 years agoHi,
- Yes, this still needs to initialize the register.
- It requires to configure the register via the AVMM interface. You may refer to the example design for the simulation.
- That is correct. You can refer to figure 42 for the detail of the command_config register.
Regards -SK
