Nicole04
2 years agoTriple Speed Ethernet IP Example Design Agilex 5
Hi, I tried compiling the Triple Speed Ethernet IP Example Design for the Agilex 5 E-Series device. The compilation fails with the errors shown in the attached image. I was able to compile other IP...
ZiYing_Intel
2 years agoHi Nicole,
May I know the OPN number of the device that you use?
Zying
Nicole04
2 years agoHi Zying,
I was using the A5ED065BB32AI4S, but for testing purposes I can use a different 32x32mm package A5ED065 device.
I was able to compile the IP Core when using a variation without the GTS Transceiver.
Kind regards,
Nicole
