AThom47
6 years agoTriple Speed Ethernet IP - 1000BASE-X/SGMII PCS only - word alignment included?
When implementing the Triple Speed Ethernet IP with the core variation "1000BASE-X/SGMII PCS only" WITHOUT built in transceiver (Transceiver type selection is set to "None") does the IP do word align...
- 6 years ago
I have tried this in hardware since I asked and the answer from Nathan above is incorrect. The 1000BASE-X/SGMII PCS only version of the tripe speed ethernet IP actually does word alignment internally. Word alignment on the tbi interface out of the rx serdes is NOT needed.
Also, the tse user guide actually states that in the port description:
"tbi_rx_d[9:0] - TBI receive data. This bus carries the data from the external SERDES. Synchronize the bus with tbi_rx_clk. The data can be arbitrary aligned."
Just wanted to update if anyone else is ever wondering about this.
Nathan_R_Intel
Contributor
6 years agoYes sure, thanks for discovering my technical mistake
