HBhat2
Contributor
6 years agoTransceiver Toolkit Loopback modes
Hi, I am using transceiver toolkit on Stratix 10 SoC Dev kit to check the transceiver line performance. Under Loopback mode option I am seeing 4 options Off Metallic Reverse Serial Serial Lo...
CheepinC_altera
6 years agoHi HPB,
Regarding your latest inquiry on the loopback between different channels, sorry as this is not supported due to hardware architecture. The internal loopback path is available only within the same channel. Sorry for the inconvenience.
HBhat2
Contributor
6 years agoHi,
Thanks for your input. I was just checking the possibility of loopback between 2 different channels. Also, in the user guide, I have not found the information that Loopback modes supported within the channel only.
With Regards,
HPB
