HBhat2
Contributor
6 years agoTransceiver Toolkit Loopback modes
Hi, I am using transceiver toolkit on Stratix 10 SoC Dev kit to check the transceiver line performance. Under Loopback mode option I am seeing 4 options Off Metallic Reverse Serial Serial Lo...
CheepinC_altera
6 years agoHi HPB,
Thanks for your update. Regarding your latest note, I would recommend to follow the user guide. For GXT channels, it does not support reverse serial loopback.
Thank you.
HBhat2
Contributor
6 years agoHi @cheepinc_Intel ,
One more clarification required regarding basic Loopback concept.
Till now I have done Loopback for TX to RX in the same Channel. For example, Bank 1D Channel 0 - TX0 to RX0 (Channel 0 TX to RX) loopback done and tested.
Is it possible to Loopback between different channels ? For example, Bank 1D- TX0 to RX1 (Loopback from Channel 0 TX to Channel 1 RX)?
With Regards,
HPB
