HBhat2
Contributor
6 years agoTransceiver Toolkit Loopback modes
Hi, I am using transceiver toolkit on Stratix 10 SoC Dev kit to check the transceiver line performance. Under Loopback mode option I am seeing 4 options Off Metallic Reverse Serial Serial Lo...
CheepinC_altera
6 years agoSure. I will update you if there I come across any detail on the metallic mode in future. thank you.
HBhat2
Contributor
6 years agoHi,
Also, I noticed that in the L tile userguide there is a note under 5.9. Loopback Modes chapter
Note: Intel Stratix 10 transceiver channels configured in GXT mode do not support Pre-CDR reverse serial loopback and Post-CDR reverse serial loopback.
When I open the toolkit and the toolkit shows the data rate to be 20.625Gbps, but reverse-Serial Loopback option is still available with the dropdown button.
With Regards,
HPB
