14 years agoTotally confused by the DDR2 high performance controller II
The user guide from Altera is bad ! Who can teach me how to use the following inputs? local_address local_be local_burstbegin local_read_req local_write_req local_size local_wdata...
14 years agoWell, the Avalon-MM bus is way much easier to work with, so I think it'd be better for You to check it out :)
Or if You really really don't want to use Avalon-MM, then download Avalon-MM memory master read/write examples. Those signals in Avalon-MM are probably the same as exported from the core generated by megawizard.
