ALast5's avatar
ALast5
7 years ago
TLP request with Root port to endpoint
I had a problem with the Read Config Type 0 request from the Root port to the endpoint
I use the CRA interface and my query is
32'h 04000001
32'h0000170F
32'h00000000
32'h00000000
I use one endpoint and one communication line, cfg_bus [12: 0] on both devices shows 13'd0.
Ltssmstate [4: 0] takes the value 0x0F and lane_act [3: 0] takes 0x01.
The problem is that when sending a request from the Root port, it receives it and responds to it (gives its configuration space to the Root port) and the data does not reach the endpoint, I use Cyclone 5, tell me what could be the problem?
  • ALast5's avatar
    ALast5
    Solved a problem
    First, I assigned the device number and bus number
    0x44000001
    0x0000100F
    0x00000018
    0x00010100
    and then done the configuration read type 1
    0x05000001
    0x0000100F
    0x01080000
    0x00000000
    thanks for the help
  • Hi there, sorry for being late, we will find someone to address your question.
  • BoonT_Intel's avatar
    BoonT_Intel
    Hi Sir,
    Let me clarify, do you mean the endpoint is ack with the config_read request but never return a data?
  • ALast5's avatar
    ALast5
    That's right, as I understand it, this is connected with routing, but apparently I don’t understand how to use it correctly, or is it connected with "enumeration"?
    Sorry for my bad english
    Sincerely, Alexander
    BoonT_Intel
    Hi Sir,
    can you help to show us fro where you observe the ACK and waiting for the data? Do you try with other address? Also, if you perform memory read, will you facing the same issue?
    Yes, usually config_read/write is happen during enumeration automatically, user do not need to trigger it manually. May I know is the enumeration is complete at the root port?
  • ALast5's avatar
    ALast5
    I probably did not say so. I'm on the Root port side. I'm trying to get device configuration space. I guess I do not completely do enumration.
    BoonT_Intel
    Hi, Ltssmstate [4: 0] takes the value 0x0F and lane_act [3: 0] takes 0x01. show the link are up. with this we can assume the enumeration is completely done.
    can you give a try on doing same config read to other endpoint? Or try with different address
  • ALast5's avatar
    ALast5
    Unfortunately, there is no possibility to use another endpoint. How to configure routing? To use queries Read Config Type 1?
    BoonT_Intel
    Routing done by header 0 and header 1.
    Header 0 is for endpoints (device) while header 1 is for rootcomplex, SWs and bridges.
    BoonT_Intel
    Hi Sir,
    Glad to know it is solve.
    Can you help by briefly explain how you decode these:
    0x44000001
    0x0000100F
    0x00000018
    0x00010100
    0x05000001
    0x0000100F
    0x01080000
    0x00000000
    This may help others whose using CRA interface.
