ALast5
7 years agoTLP request with Root port to endpoint
Hello, I had a problem with the Read Config Type 0 request from the Root port to the endpoint I use the CRA interface and my query is 32'h 04000001 32'h0000170F 32'h00000000 32'h00000000 I use...
BoonT_Intel
7 years agoHi, Ltssmstate [4: 0] takes the value 0x0F and lane_act [3: 0] takes 0x01. show the link are up. with this we can assume the enumeration is completely done.
can you give a try on doing same config read to other endpoint? Or try with different address
