SERMASWATHIKA
Contributor
2 years agotiming_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team, I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setti...
TingJiangT_Intel
Contributor
2 years agoYou don't need to constraint all the clocks, just apply it to the clocks of asynchronous path( the launch and latch clock ).
BTW you can try to apply the following constraint:
'derive_pll_clocks'
- SERMASWATHIKA2 years ago
Contributor
Hi ,
I have tried with derive_pll_clock also. but still facing timing violation issue.
do i miss anything?
