SERMASWATHIKA
Contributor
2 years agotiming_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team, I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setti...
TingJiangT_Intel
Contributor
2 years agoThe setup violations showed in the report are all asynchronous path. You can use 'set clock group' constraint to eliminate the relationship between 'inst|ddr3|pll0|pll_dq_write_clk ' and 'dqs_n[3]_OUT'.
- SERMASWATHIKA2 years ago
Contributor
Hi Ting,
I have added constraint for the clocks like you have mentioned, but still facing the timing violation error:
could you please give suggestions whether this constraints are okay?
