anonimcs
Contributor
2 years agoTiming constraints of Intel IPs
Hi all, I have a design on Quartus 21.3 Pro and I noticed that the External Memory Interface IP for DDR4 memory has some timing violations within the IP core. I would expect that these kind of IP co...
RichardT_altera
2 years agoAs we have IP experts for the respective IPs, could you file a new case requesting the EMIF IP owner to review your IP?
They can check if there are any configuration settings that might help with the timing. Typically, the timing within the IP is already managed by the IP's SDC file.
Richard Tan
- anonimcs2 years ago
Contributor
Can't you just forward this forum entry to those experts internally ? I think it would make the most sense for them to see what we've discussed and tried out until this moment.
Cheers.
