lambert_yu's avatar
lambert_yu
5 years ago
the Tdivw_total & VdiVW_total of DDR4-2666 when use the EMIF IP on Arria 10
Hi all, I have one problem, when I customize the EMIF IP on Arria 10, the Tdivw_total & Vdivw_total should be set following the value in the datasheet of MT40A512M16LY-075, or should be kept f...
  • yoichiK_altera's avatar
    5 years ago
    Hi Lambert
    The Tdivw_total and Tdivw_total parameter slightly differs across the DDR4-2666 bin. Please check the datasheet which you use actually and use the number on the datasheet.
