BXia
4 years agoThe max output frequency of fPLL Intel Arria 10 FPGA IP
We are using the fPLL Intel Arria 10 FPGA IP, the input reference clock is set to 100MHz, PLL output frequency is set to 2GHz, as shown in the attached screenshot.
However, we found the act...
Ash_R_Altera
4 years agoHi,
You are right.
The PLL max output frequency is limited by the VCO frequency which is 1.6GHz. Please refer the datasheet for IOPLL specifications:
BXia
4 years agoHi,
Thanks for your reply.
However, we are using fPLL, but not the IOPLL, we refer to Fractional PLL Specifications (attched image here), the max frequency is 14GHz.
Are the fPLL and IOPLL have the same specifications?
