12 years agoTest pattern generator from the Altera VIP suite
there seems to be a problem with the test pattern generator in conjunction with Quartus 13.1. When I run elaboration Quartus fails because the TPG component does not contain any ports. When I run the block symbol creator an empty block is created. The same TPG design does work with Quartus 13.0sp1. JanNo RepliesBe the first to reply
