Vamsi_21
3 years agoSystem console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi, I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document. https://www.intel.com/content/www/...
ZiYing_Intel
2 years agoHi Vamsi_21,
Currently I don't have any update. I now transition this thread to community support. The community users will continue to help you on this thread.
zying
Vamsi_21
2 years agoHi,
Is there any hardware_test_design avaialble for Low latency 100g Ethernet intel FPGA ip example design.
I have generated an example design but it isn't working on the hardware , I am getting the below error:
"TTK failed reading from PHY slave_10000, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset."
This error is same as the one i got for 10g ethernet design , so can you help me on this issue for the 100g design as well.
