Vamsi_21
3 years agoSystem console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi, I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document. https://www.intel.com/content/www/...
ZiYing_Intel
2 years agoHi Vamsi,
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
- Vamsi_212 years ago
- Hello,
Iam testing with the tcl scripts which you have shared and need some time analysing them because previously when i tested on the board i got the same results for every test irrespective of channel, data- rate , burst size
- Hello,
As I have mentioned above , I have checked with the .tcl scripts you have shared and found the output was same irrespective of any test_speed , can you look into this issue?
@ZiYing_Intel
