Vamsi_21
3 years agoSystem console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi, I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document. https://www.intel.com/content/www/...
ZiYing_Intel
2 years agoHi Vamsi,
Here's the .tcl script.
zying
- Vamsi_212 years ago
I have tested on the board with the .tcl scripts you have shared and have found the irrespective of any changes like burst-size, data rate and different tests like PHYSERIAL_LOOPBACK and SMA_LOOPBACK
It is showing same "throughput calculated" for every speed.
Below I am attaching the screenshots for:
PHYSERIAL_LOOPBACK for channel 0 , 1G speed, 1000 burst size,
PHYSERIAL_LOOPBACK for channel 0, 10G speed, 1000 burst size,
SMA_LOOPBAACK for channel 0, 10G speed, 1000 burst size.
device details:
NAME: ARRIA 10 GX development board
DEVICE: 10AX115S2F45I1SG
