Vamsi_21
3 years agoSystem console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi, I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document. https://www.intel.com/content/www/...
ZiYing_Intel
2 years agoHi Vamsi,
I already sent the example design to your email and glad to hear that you can run successfully. For the issue on 100G, can you share your .qar file here?
zying
Vamsi_21
2 years agoHi,
Can you the share the .tcl scripts for 10G Etherent which you have used for testing on the board because for any test i run iam getting the same output irrespective of the channel, data-rate, burstsize .
