Vamsi_21
3 years agoSystem console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi, I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document. https://www.intel.com/content/www/...
ZiYing_Intel
2 years agoHi Vamsi,
I already sent the example design to your email and glad to hear that you can run successfully. For the issue on 100G, can you share your .qar file here?
zying
- Vamsi_212 years ago
Can you the share the .tcl scripts for 10G Etherent which you have used for testing on the board because for any test i run iam getting the same output irrespective of the channel, data-rate, burstsize .
