Vamsi_21
3 years agoSystem console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi, I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document. https://www.intel.com/content/www/...
ZiYing_Intel
3 years agoHi Vamsi_21,
I just get to know that the EyeQ is no longer supported in A10 devices. It seems to be due to some issue with the EyeQ result. Please avoid using the EyeQ. Do you use the EyeQ?
zying
Vamsi_21
3 years agoHi, I am not using EyeQ,
I am using signal tap logic analyzer tool.
