System console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi Vamsi_21,
Could you try enable NPDME option and try testing again on hardware?
zying
I have enabled NPDME option and generated the example design.
I have given the pin assignments as follows
NAME pin assigned
mm_clk BD24
ref_clk_10g AN8 (modified using clock controller)
While testing on the hardware , i am getting the below error from system console.
error:TTK failed reading from PHY slave_2000, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset.
error: open_service: Could not open service at /devices/10AX115H(1|2|3|4|4E3)|..@1#2-13/(link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_1/jtag_phy_0.jtag/master: Channel busy
while executing
"open_service master $port_id"
(procedure "reg_write" line 4)
invoked from within
"reg_write $PHY_IP_BASE_ADDR $seq_control 0x141"
(procedure "SETPHY_SPEED_10G" line
invoked from within
"SETPHY_SPEED_10G"
(procedure "CONFIG_1PORT" line 10)
invoked from within
"CONFIG_1PORT $speed_test"
(procedure "TEST_PHYSERIAL_LOOPBACK" line 10)
invoked from within
"TEST_PHYSERIAL_LOOPBACK 0 10G 1000"
Below i have attached the screenshot of the error.
