16 years agoStratix4GX PCIe development board to used as root port
I wanted to know if anyone has used the Altera Stratix4GX PCIe card as a root port. I have used it as endpoint but have not used as a root- port. As an endpoint all I have to do is plug in t...
16 years ago --- Quote Start --- You cannot connect your root port in the Stratix4GX with the root port on the motherboard. There must be only/exactly one root complex in the PCIe fabric, just like in PCI where you can also have just one root complex that drives DEVSEL#, etc. Please refer to PCIe Spec Section 1.3 »PCI Express Fabric Topology«. Again, it’s not possible the way you want it. You can only drive your own, separate PCIe link as a root port as described above: Design a motherboard with your Stratix4GX as the root port, and it will work. But I’m still not convinced that a root port is what you really want to instantiate. As an endpoint in a PCIe slot, you can act as a bus master and issue DMA transfers on your own, issued by your CPU. But you cannot be another root port. Period. I cannot help you for the BAR question as I am not into root port design. --- Quote End --- From your feedback, I get the impression that the FPGA endpoint can handle this. But I am not sure. In this scenerio, can the FPGA endpoint start talking to the root-port chipset on power-up (or cold reset)? There may be low level handshake between the root port chipset and the FPGA endpoint - on power up but I am not sure if that enables the FPGA endpoint to start talking like a real processor to the root-port chipset. Basically the PCIe link between the FPGA end-point and the root-port needs to be primary bus. I am not sure if this is possible.
