Stratix10 PHYLite: avl_readdata on Avalon Interface Always Returning 0
Is there any expected result from readdata signal from any address? Such as at initial address?
Maybe you can check the timing report for any timing issue. If timing issue exist in the design, you can try to fix that first.
You also can try to reduce the DQ width to create a smaller interface in PHYLite IP.
Therefore, you can connect directly to NIOS with Address Span Extender IP.
Have you verified the PHYLite IP can perform read and write transfer successfully with the example design?
Adzim
- vinupriya1 year ago
I'm reading the PHYLite table as mentioned in the user guide. Please check the guide for more details.
It’s working fine in simulation.
However, I didn’t see any readdata from any address.
I also checked the timing report - there are no timing issues in the design
