10 years agoStratix V Native Phy
Hi all i'm working on "Transceiver Signal Integrity Development Kit" with strativ V GX. i'v already worked with 10Gbase-R Transceiver phy with no problem, and i tested my design with an Ethernet...
9 years ago --- Quote Start --- Hi alli'm working on "Transceiver Signal Integrity Development Kit" with strativ V GX.i'v already worked with 10Gbase-R Transceiver phy with no problem, and i tested my design with an Ethernet analyzer Device.but i need to use Native Phy in PMA Direct mode, to use the line data for mapping in another protocol.in first step i tried to loop the rx data to tx data, to test the design with Ethernet analyzer, but it doesn't work, when tx data rate is 10Gbit/s, the rx data rate is approx. 8Gbit/s. indeed, rx data rate is always less than tx data rate.something is wrong, but i can't understand what is.i'v studied all altera documents about Transceivers and i'v reviewed the altera online training in this field.has anybody no idea about that.i can present more details about my design in case of need. even attach the project here.thanks a lot --- Quote End --- Hi, I have met the same problem. Did u solved this? If u have solved , can you tell me the way. Thanks.
