10 years agoStratix V Native Phy
Hi all i'm working on "Transceiver Signal Integrity Development Kit" with strativ V GX. i'v already worked with 10Gbase-R Transceiver phy with no problem, and i tested my design with an Ethernet...
10 years ago --- Quote Start --- Have you tried simulating your design? That is typically the best way to debug a problem. There is no point in submitting a Service Request if you cannot submit a simulation demonstrating the issue. The examples I posted should have simulation examples, so you can use those as the basis of your simulation. Cheers. Dave --- Quote End --- Thanks dear Dave yea, it could be a good idea. Ok i'll do the simulation and make a Service Request to Altera.
