10 years agoStratix AVMM with DMA Gen3x8 example ..... how to add CRA translation
The Stratix AVMM with DMA is a design with AVMM 64 Bit address ... I would like to make the AVMM address 32 bit and have the CRA translation enabled.
Does anyone know the method to edit the "AVMM with DMA " component to enable the CRA translation ? My alternative that I did once was to append the upper 32 bit to the existing 32 bit AVMM address and present the 64 bit address to the TXS port ... this worked Ok but from a legacy perspective is not compatible with designs where the CRA translation for 32 -> 64 bit PCIe is achieved via the CRA translation. Best Regards, Bob.No RepliesBe the first to reply
