User1573261788318367
6 years agoStratix 10M PCIe BAR0 size incorrect
Hi, I have a super simple design right now. The Stratix 10M PCIe HIP (generated in qsys) has its rxm_bar0 interface exported, and this IP is instantiated in a top-level wrapper. In Qsys, I've config...
6 years agoSome more strange behavior. If I comment out the code to memset and msync, I can read entire kilobytes off data off of the bus. HOWEVER, I can only read it 32b at a time. If I try to memcpy a large number of bytes from the uio0, then I get 0xffff_ffff for all the readback data, which is incorrect. If I read the values in a loop 32b at a time, I get 0xdead_beef, which is the expected result.
So, it looks like there is something wrong with *writing* more than 16B at a time to uio0, but reading is fine...
