roeekalinsky's avatar
roeekalinsky
4 years ago
Stratix 10 UCID IP bug: partition conflict
If the S10 UCID IP is used and its clock input comes from a sector clock gate, Quartus errors out during the fitter stage with the following message:
Error (19732): Sector clock gate s10clkctrl_ip_i|stratix10_clkctrl_0|clkena_inst drives to auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|mboxfabric|command_0_reset_handler_0|state[2] which is in a different partition. Sector clock gates and their destinations must be in the same partition.
What appears to be happening, big picture, is that Quartus is doing some behind the scenes "magic" to implement the UCID IP, and then trips over itself downstream.
More specifically, during synthesis Quartus automagically creates a bunch of interface logic to bridge the UCID IP's interface to the SDM, and it takes the liberty to create a dedicated partition called "auto_fab_0" for this auto-generated interface logic. Then later, during the fitter process, Quartus rightly complains about the fact that this interface logic is not on the same partition as the sector clock gate that feeds it.
Attached is a trivial design example that demonstrates this problem.
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    For now, there is no any resolution for this limitation. Error message will be shown if there is any violation. But anyway, i will feedback this to internal team.
