Stratix 10 PHYlite : initial data on the data_io port of the PHYlite is missing at data_to_core
Can you check the design for the timing compilation?
Maybe there is timing issue in the design.
Can you test with the example design as well?
Adzim
- NMR1 year ago
I am facing this issue during functional simulation
- NMR1 year ago
Hi AdzimZM,
I evaluated the example simulation design using my PHY Lite IP configuration settings. Even within the example design, I observed frequent occurrences of incorrect read data, as illustrated below.
The data sampling mechanism from data_io to data_to_core is not entirely clear to me(the alignment of data on data_to_core(LSB to MSB) differs between the example design and PHY Lite document). In my actual design, the data_to_core signal fails to capture the initial few data words. In contrast, the example design does capture the initial data, but intermittently misses some intermediate data.
Kindly assist me in identifying and resolving the issue
Group 1,
Group 0,
correct
Mismatch
