WGith
7 years agoStratix 10 Mailbox Client IP Interface
Hi, I am trying to interface with the SDM via the Mailbox Client IP. I have created my own AVALON like interface to communicate with the mailbox client. I have been able to successfully read the C...
YuanLi_S_Intel
7 years agoHi William,
This is expected if your S10 Design doesnt contain a remote system update host controller and a Mailbox Client Intel Stratix 10 FPGA IP. Please refer to link below for the design needed to perform RSU.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-config.pdf (Page 122)
YL
- WGith7 years ago
HI, I followed the app note and created the following mapping. BLOCK START ADDRESS END ADDRESS BOOT_INFO 0x00000000 0x0010FFFF FACTORY_IMAGE 0x00110000 0x00487FFF (0x00443FFF) SPT0 0x00488000 0x0048FFFF SPT1 0x00490000 0x00497FFF CPB0 0x00498000 0x0049FFFF CPB1 0x004A0000 0x004A7FFF P1 0x004A8000 0x007DBFFF Configuration device: 1SG085HN1AS Configuration mode: Active Serial x4 Notes: - Data checksum for this conversion is 0xB3D7AA8A - All the addresses in this file are byte addresses I then loaded the flash with my new .jic file and then loaded the design. I am now able to get status back from usercode 0x5b which points that I loaded the image at 0x004A8000. I still can’t get user command 0x5C to work no matter what I do. I am sending the following commands at the moment Base+0 , 0x5C(command), 0x2 (length) Base+0, 0x0(command), 0x0(length) Base+1, 0x004A8000(start address)
