WGith
7 years agoStratix 10 Mailbox Client IP Interface
Hi, I am trying to interface with the SDM via the Mailbox Client IP. I have created my own AVALON like interface to communicate with the mailbox client. I have been able to successfully read the C...
YuanLi_S_Intel
7 years agoHi William,
I have tested the command on v19.1 Pro and it seems like there is no problem in executing it. It seems to me that it might be due to command execution flow issue. I have included the flow to execute the command in TCL using system console:
global omp b0 b1 b2 b3 b4 b5 b6 b7 b8
#writing the command header (Get_IDCODE)
master_write_32 $omp $b1 0x00000010
#Read ISR (Expect to get 0x3)
set ISR [master_read_32 $omp $b8 1]
while {$ISR != 0x00000003} {
puts "ISR is not ready yet!"
#Read Response FIFO fill level, EOP and SOP (Expect to get 0x9) (optional)
set SOP_EOP_FIFO [master_read_32 $omp $b6 1]
while {$SOP_EOP_FIFO != 0x00000009} {
puts "SOP_EOP_FIFO is not ready yet!"
#read offset 5 for the first packet of data (Expect to get 0x1000)
master_read_32 $omp $b5 1
#Read Response FIFO fill level, EOP and SOP (Expect to get 0x6) (optional)
while {$SOP_EOP_FIFO != 0x00000006} {
#read offset 5 again to retrieve the response argument (in this case, this command only has one response argument, which is the IDCODE)
Hope it helps.
YL
WGith
7 years agoHi,
I was able to figure out my problem. I was given AN 891, Using the Reset Release Intel Stratix 10 FPGA IP.
I didn’t change anything in my code except connected up this block to my reset signals and now I see 0x3h as my response in the ISR.
Thank you,
--Will
