MIT_R_D's avatar
MIT_R_D
5 years ago
Stratix 10 L- Tile: Reverse Serial loopback Mode- electrical idle
Hi I need info about electrical idle When we are in Reserve Serial Loopback(Metalic). whether tx is disabled during electrical idle is receiving on Rx line or will be consider as 1 or 0 and tran...
  • CheepinC_altera's avatar
    5 years ago
    Thanks for your update. Please see my responses as following:
    Here my query is when our S10 SERDES is RSL mode, if HW1_RX1 is receiving combination of data's and electrical idle, same SERDES HW1_TX1 will transmit same data's and electrical idle or not?
    [CP] As I understand it, with the pre-CDR reverse serial loopback, the data received by RX buffer will be loopback to the TX buffer to be transmitted out. When the HW1_RX1 is receiving electrical idle, there will be no data passing to the TX buffer.
    Due to no specific characterization or detail in the user guide, I am not sure what will be the HW1_TX1 output state. You might need to perform a test on hardware to tell. Sorry for the inconvenience.
    Note that the different loopback modes are generally for debugging purpose only. It is not meant for production usage.
    Please let me know if there is any concern. Thank you
