Stratix 10 Calibration Native Phy and Atx Pll
- 3 years ago
Q1. Can I use fpll as MCGB and dynamic reconfiguration it with profiles?
Ans - Yes.
Q2. Can I use fpll with mcgb and dynamic reconfiguration and atx pll with mcgb without dynamic reconfiguration. They goes to native phy serial clk 0 and 1. And I can mux them in native phy via reconfiguration interface.
Ans - It should be, please looked into the IP, If there are profiles in the dynamic reconfiguration tab, then profiles are supported.
Q3. Can i use fpll in Transceiver mode for 7GHz?
Ans - Maximum frequency for fPLL is 12.5Gbps (6250MHz).
Thank you
Kshitij Goel
If you are using E-Tile device, It is mandatory to do the initial adaptation. Also, It is expected there would be significant differences in calibration time between simulation and hardware.
Thank you
Kshitij Goel
- Petkov_Alex3 years ago
Ok, thanks. Can you explain or describe, what affects on calibration time in hardware?
