Petkov_Alex
3 years agoStratix 10 Calibration Native Phy and Atx Pll
Hello. I have read document xcvr h/l tile stratix 10, and tested my project in ModelSim I have 4 channels native phy with multiple profiles saved and embedded reconfiguration streamer 2 Atx pll with...
- 3 years ago
Q1. Can I use fpll as MCGB and dynamic reconfiguration it with profiles?
Ans - Yes.
Q2. Can I use fpll with mcgb and dynamic reconfiguration and atx pll with mcgb without dynamic reconfiguration. They goes to native phy serial clk 0 and 1. And I can mux them in native phy via reconfiguration interface.
Ans - It should be, please looked into the IP, If there are profiles in the dynamic reconfiguration tab, then profiles are supported.
Q3. Can i use fpll in Transceiver mode for 7GHz?
Ans - Maximum frequency for fPLL is 12.5Gbps (6250MHz).
Thank you
Kshitij Goel
Petkov_Alex
3 years agoNo, you did not understand, my OSC_USER_CLK1 is stable and free running, and has 100MHz clk, and it selected in project settings.
My Reconfig_clk has 125 MHz and takes Several Millions of clock beginning from start of reconfiguration and recalibration to pll locked and calibrated. But if I do not recalibrate, pll not locks at all
