Stratix 10 Calibration Native Phy and Atx Pll
- 3 years ago
Q1. Can I use fpll as MCGB and dynamic reconfiguration it with profiles?
Ans - Yes.
Q2. Can I use fpll with mcgb and dynamic reconfiguration and atx pll with mcgb without dynamic reconfiguration. They goes to native phy serial clk 0 and 1. And I can mux them in native phy via reconfiguration interface.
Ans - It should be, please looked into the IP, If there are profiles in the dynamic reconfiguration tab, then profiles are supported.
Q3. Can i use fpll in Transceiver mode for 7GHz?
Ans - Maximum frequency for fPLL is 12.5Gbps (6250MHz).
Thank you
Kshitij Goel
Please share the OPN.
Have you selected the correct configuration clock source(i.e. 125 MHz OSC_CLK_1 pin) in Device and Pin options?
Please refer the Calibration chapter in L- and H-Tile Transceiver PHY User Guide.
Also, the time required to complete the calibration process after device power-up can vary by device.
Thank you
Kshitij Goel
